Perform this procedure to configure the remote Intermediate-System-to-Intermediate-System (IS-IS) Shortest Path Bridging MAC (SPBM) parameters on a specific port.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface mlt <1-512>
  2. Configure the remote IS-IS SPBM interface type:
    isis remote spbm <1-100> interface-type {broadcast | pt-pt}
  3. Configure the cost of the remote SPBM instance:
    isis remote spbm <1-100> l1-metric {<1-16777215> | auto}
Configuring the remote IS-IS SPBM interface type and layer 1 metric on port 1/2:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabitEthernet 1/2
Switch:1(config-if)#isis remote spbm 2 interface-type broadcast
Switch:1(config-if)#isis remote spbm 2 l1-metric 2
The following table defines parameters for the isis remote spbm command.
Variable Value
<1-100>
Specifies the SPBM instance.
Specifies the IS-IS SPBM interface type as broadcast or point-to-point (pt-pt).
l1-metric {<1–16777215> | auto}
Specifies the SPBM instance Level 1 metric on the IS-IS interface located on a specific port. You can configure a static value, or use auto. When you use the auto setting, the network route is determined by summing the lowest value metrics, which are inversely proportional to port speed.
